Hi Fellows,
I've in hands a strange amp.
First impression are good but I had a loud background noise and a loud humming when I touch the pot knob.
So I opened it up and.....wires are not isolated meaning signal wires are in contact with ground....
The pot case or pot terminal?... a loud humming when I touche the pot.
Terminals: normal
Case: Usually used for shielding...normally at signal return potential.
...câbles are not isolated meaning signal cables are in contact with ground....
Looks like RCA connectors are isolated from mounting plate.
Look for a single common ("star) "ground" connection point.
Thanks, when i touch pot knob.
What concerns me is that power, ground and signal cables are in contact.
Will try to find the star point
Perhaps re-wire it with proper insulated wires or harvest parts.
Probably the best thing to do ;-)
- Chip Amps
- Chip topology
