Chip Amps for Record Player
Oh woaw! LM1875T ... I know 1876T exists but this...?
It should be more like 1875F (FAKE) But absolutely I might even work.
It mainly depends on the recordplayers output voltage. If its near 2V RMS it should be fine. But I really havent seen any that has it so high. Then yes, you do need a preamp
i'm not sure you need pre-amp.
if it ain't as loud as it should be, you can increase the gain .
so for now just build the reference design,
try it.
then try it with your... say computer as a source.
if it louder on your computer than on the record player, then adjust the gain setting resistors a bit. you can download the datasheet of the chip, gain calculation is found within it.
Joined 2009
Bogus! The LM1875T is made by TI. You can convince yourself of this pretty easily by looking at the data sheet and product page available here: LM1875 | Mid/High-Power Class D Amplifiers | Audio | Description & parametrics
Now, whether the eBay kit comes with a real or a fake LM1875 is anybody's guess. If, on the other hand, you buy the parts from the TI distributors (Mouser, Digikey, Newark, et al.) you're 99.9999999 % certain that you'll get a real part.
The LM1875 is a fine little mid-power IC amplifier. Nothing wrong with it.
To use any power amp with a record player (aka turntable), you'll need a RIAA preamp (aka phono preamp).
Tom
