I'm thinking of getting one. I might also get an ordinary chassis-mounted filter as I already bought an IEC plug. I'm not sure but would a chassis-mounted filter do the same job as an IEC plug filter.
If I do use a chassis-mounted filter, is the metal casing connected to the mains ground?
Also, how do I select one based on amperage? It comes in 2A, 4A and 6A. I'm thinking of getting the 6A.
Also, I've seen in catalog where a chassis-mounted filter has an earth line choke. what is it?
Any ideas/suggestions are greatly appreciated.
