heloo
I am new in tube PSU design, and I want to change diodes in attached link to schematic with 5AR4 or similar tube. Could someone draw me how to do that...
lp
trens
PSU schematic
lp
trens
PSU schematic
Look before you leap. The 1300 VAC CT exceeds the PIV rating of the 5AR4. So, you can't use a 5AR4.
5AR4 Data Sheet
You could use a pair of damper diodes to replace the SS diodes. Be aware that the forward drop in vacuum rectifiers is greater than that of SS. You will also need additional heater power.
Oh yeah, plates are anodes (SS triangles) and cathodes are cathodes (SS bars). The SS diode symbol indicates the direction of conventional current flow.
5AR4 Data Sheet
Eli Duttman said:The 1300 VAC CT exceeds the PIV rating of the 5AR4. So, you can't use a 5AR4.
o.k. then some other rectifier tube .... I told that I am new in tube PSU
lp
trens
plovati said:A couple od 3B22. ][/B
Hmm. My datasheet says PIV is 725 volt for 3B22. To low.
Benny
3B22s are not so hard to find:
http://www.thetubestore.com/cetron3b22.html
it can be uses by a series of diodes and 3B22.
Or, from the same family, 3B25, rectifies up to 1400V dc
http://www.tubedepot.com/nos-3b25.html
Big amplifier, big rectifier!
Hello again
I was thinking.
Is it possible to use EY500 (PY500) rectifier tubes? This tube are easy to get and cheap (used in all old TV set).
The average current is 425 mA (800 mA peak).
PIV = +5kV.
I have never used this valve, so I do not know it is a usable idea.
Benny
I was thinking.
PIV = +5kV.
Benny
Indeed you should be able to use the PY500,s. They are reputed to be more reliable in the long term.
However you have to face the fact that you will need two of them, and if my memory serves me correctly - they draw considerable heater current - which might mean a seperate heater transformer. I seem to remember that underrunning them might adversely effect their durability.
Shoog
Shoog
- Tubes / Valves
- changing diodes with 5AR4 tubes
