I got an old JVC (HX GD-8) stereo amplifier. this amp is a bit special, because it has two seperate subwoofer outputs on each channel. I'm only using one channel, and I'm using a SEAS L26ROY 10" subwoofer. the problem is that when I play songs with hard bass puches at high volume, it sounds like the amp don't get enough juice to provide all the power.
I found a service manual at the internet, and i disassembled my amp. I found out that each subwoofer channel only had 4700uF caps! is that the reason why the sound (hard punches, not pure bass) sounds weird?
I found some caps on ebay. Do you think 10000uF at each channel is enough? The caps inside the amp is rated 71v. Is it a problem if I replace them with 63v or 100v caps instead? The subwoofer channels is powered by an STK412-430, but I can't find a good datasheet on that one.
Amplifier manual:
http://resources.jvc.com/Resources/00/00/95/GVT0125-001A.pdf
Sub: 6R - 16R
Speaker:
The Madisound Speaker Store
4R
Might be an issue.
Sub: 6R - 16R
Speaker:
4R
Might be an issue.
yup, thats a bummer, I know. but do you think that changing capacitors might help anyway? A pair of 10000uF caps isn't so expencive. Is it worth a try?
It's only a 195W sub output and that might be exagerated.
A 10" sub at full pelt may well be starved of power at high volume.
Your amp may have limiting based on a 6R min load.
Big caps won't change that.
