CFP output stage adding more output transistors
Ian Finch
2010-04-11 4:22 am
Coffs Harbour, NSW
I'd post that question on Rod Elliott's forum or at least search threads there on the P3a. It seems just about every DIY around the planet has played with trying to build their own version and the question would have arisen many times. It's likely been discussed here too if you care to search it.
Having said that, if you read real books and came across Douglas Self's "Audio Power Amplifier Design Manual" or "Self on Audio" in the later editions, you'd come across his "Load Invariant" design which is a "blameless" style CFP amp with 2 pairs of MJL3281/1302 driven by MJE340/350. In a nutshell, the output transistors are simply wired in parallel.
'Nothing complicated, bar the heavy emphasis on very good thermal bonding of the bias transistor to the driver transistor(s) - a lot more positively than in the the P3a, anyway. The issues with CFP are poorly understood thermal compensation schemes and stray inductance (long runs and messy routing) in the output stage, so top-notch PCB layout with increasing care as the number of pairs increases and then base stopper resistors, cap. and zobel bypasses may have to go in too.
CFP can be fine but it doesn't handle stray reactances too well. Keep it simple, short and neat and there should be no oscillation problems for only a few pairs.
