I always have problems with transformers.
I want to use a central tap transformer no toroid in a brian mini aleph PSU.
What I have to do.?
thanks
ricardo
What I have to do.?
thanks
ricardo
I may see your confusion. On the power supply board there
are 4 ac inputs 2 for one transformer winding and 2 for the
other one spaced like ac ac ac ac . But if you
look at the back of the board the 2 center ac inputs are joined together this is where you would connect the center tap winding
of your transformer. Then the other 2 transformer leads to
the outside ac inputs.
