Hi all,
I bought a pair of these speakers on ebay, and they have arrived today.
It seems I have an odd pair. One looks as though the surround has been replaced. It seems like a slighty different material, though both are rubber like and of the same design.
The problem is, the one that seems to have had its surround replaced starts to make a vibrating rattly kind of noise in the lower frequencies, lower than about 60Hz. This is at very, very little volume too.
I know it's not a lot to go on probably, but is there any chance that this is easily fixable? I don't know all that much about speaker construction.
Is it likely a case of redoing the surround?
edit - I should add, if I gently place my finger on the edge of the cone, the rattling stops and all sounds fine.
