Hi, everybody!
I`m new here and need some help for troubleshooting. Have a Micromega Trio transport with CDM9 Pro. Was sent for upgrade and came home with broken ribbon/flex cables for both laser and motor. This happend during transport. Packing can never be good enough.....😱
I understood early on that getting spares for CDM9 Pro was difficult, expect for laser that can be swapped for the regular CDM9. After some exctensive searching on the web I got in contact with a german company selling new ones. Got hold of one within a week. Great🙂
Well great until assembly was ready and this happend: When I put powercord in the player the motor starts spinning at once and won`t stop. The on/off button does not react. When I put laser cable in/out of PCB contact the speed increase/decrease but does not stop anyway. After some fumbling around it suddenly operated 100% for 15 minutes and then failed again. I don`t know how these mechanisms really work and what "triggers" this behavior?
Lasers actually come in 6 different types marked 1-6. There are industrial type, CD types, Cd rom. CDM9 have nr.2 while original Pro has 4. Well mine is 6 which is the first I have seen..........
Any suggestions were to look. Laser? motor? power supply? adjustments?
Tips is most welcome!🙂
Both CDM9 (normal motor) and CDM9pro (brushless motor) was the first mechanism, where is in use a so called LDGU (hologram laser diode) from Sharp instead a normal laser diode. The reliability of this diode is significantly worse than by normal laser diode. What you have described is exactly the same fact, that I observe, if there is a bad LDGU by my service work.
here is the datasheet and patent of this special device
http://www.datasheetcatalog.org/datasheet/Sharp/mXqxuqy.pdf
http://www.freepatentsonline.com/5511059.pdf
about
http://www.partmate.com/download/OPU/CDM9.pdf and
http://blog.sina.com.cn/s/blog_4a65750301008bfe.html
you will find a picture serie (photo galerie) of a disass'y procedure of CDM9 and the internal schematic of the LDGU.
text unfortunately only in japanese.
Here the cd player models, where CDM9pro is in use
AUDIOLAB 8000 CDM Transport CDM-9 Pro
BURMEISTER 979 Transport CDM-9 Pro
EMT 982 PROFESSIONAL TDA1547 (DAC7) CDM-9 Pro
Forsell Air Reference Air Bearing Transport CDM-9 Pro
JADIS JD-1 Transport CDM-9 Pro
KRELL KPS 20i 4 x PCM63P-K – Motorola XC56002F CDM-9 Pro ( CDM-9/60 )
MARANTZ CD-23 2 x TDA1547 (DAC7) CDM-9 Pro
PHILIPS LHH-100 CDM9 pro TDA1547
ROTEL DCM-9PRO CDM 9 pro PCM63
ROTEL RCD-990 CDM-9 Pro 2 x PCM63P ? PMD100
T+A CD1400AC SM5864 CDM-9 Pro
THETA DATA BASIC CDM-9 Pro It's a Transport
T+A CD1400AC CDM-9 Pro SM5864
Ask by one of this companies for parts and additional support.
about
Well, problem lost!
A lot of frustration, but there had to be something wrong with the powersupply and it turned out to be the powercord it self. The Micromega has a 9 pin cord and one pin was loose in one of the connectors.
Solution was so close, but yet so far away..........
Thank you for tips and help!
Hi ulle
do you have the details of the german company that you got the cdm-9 pro from?
I have a dead Micromega that needs one
Thanks C
Thanks C
Hi!
The company is Riedservice in Stuttgart.
www.riedservice.de
Good service and quick to answer. If you don`t live in Germany you have to make prepayment, but no need to worry. It is a serious company and they communicate well. Tracking number etc.
When you assemble the new drive take care of the flexicable and don`t do anything in a hurry. Cables are very fragile under pressure.
Good luck!
www.riedservice.de
Good luck!
Hello, I'm new here, and in a similar boat.
I shipped a Micromega transport, and it arrived with a torn foil to the motor part of the CDM 9 Pro. So, I'm looking for a dead CDM9 Pro laser with a good motor section.
Does anyone know the part number to the motor, or what other applications it might have been used in?
Thanks, Samir.
Thanks, Samir.
Hello all,
I know it is a late reply but, if anyone is looking for CDM-9 Pro brushless motors.
I do have some in my possession.
Regards,
Michel
Regards,
Michel
Hello ulle,
I have had those for so long that I don't even remember where they come from.
I know I took them off from CDM-9/46 drives to install DC motors so there is a good chance they could be new.
They look really clean so I wish I had an easy way to test them.
A fellow not far from me is in the process of buying one so I should know soon enough if there is a problem.
Do you still have these Michael as I am interested in purchasing one?
If so, how much are you asking for one and do the motors come with the ribbon cable that connects the motor to the drive electronics?
Hi Michel,
If you still have the brush motor with ribbon cable working for CDM9 Pro please let me know. I am interested for my CD player Theta. Thanks
More models with CDM-9 pro:Here the cd player models, where CDM9pro is in use
AUDIOMECA MEPHISTO Transport CDM-9/44 / CDM-9 Pro
BARCLAY DIGITAL F1 and X-1 CD Transport CDM-9 Pro
Burmester 939, 963 and 969 CDM-9 Pro
DUSON CD100 CS4328-KP CDM-9 Pro
GOLDMUND MIMESIS 36 It's a Transport – SAA7310GP CDM-9 Pro
INKEL (Sherwood) TEMA CD-1 TDA1547 CDM-9 Pro
MERACUS IMAGO It's a Transport – SAA7310GP CDM-9 / CDM-9 Pro
MICROMEGA DUO and DUO.CD2.1 It's a Transport CDM-9 Pro
MICROMEGA TRIO.3CD. It's a Transport CDM-9 Pro
MISSION-Cyrus Discmaster It's a Transport – SAA7310GP CDM-9 Pro
NAIM AUDIO CD1 TDA1541A-S1 (Single / Double Crown) CDM-4/27 / CDM-9 Pro
POLYFUSION AUDIO MODEL 920 It's a Transport CDM-9 Pro
PS AUDIO LAMBDA/LAMBDA TWO It's a Transport – SAA7310GP CDM-9 Pro
RESTEK RADIANT (ver. 3) CS4328-KP CDM-9 Pro
ROTEL RCD-990 and RHCD10 2 x PCM63P – PMD100 CDM-9 Pro
SUGDEN AU51 PRO and PDT10 It's a Transport CDM-9 Pro
SUGDEN SDT-1SE (SDT-1PRO) TDA1541A-S1 (Single Crown) CDM-9 Pro
T+A CD2000AC MKII TDA1547 (DAC7) – SAA7350 – NPC Filter CDM-9 Pro
T+A CM3000AC It's a Transport – SAA7310GP CDM-9 Pro (CDM-9/60)
T+A CM3000R It's a Transport – SAA7310GP CDM-9 Pro (CDM-9/60)
THETA DATA BASIC II It's a Transport – SAA7310GP CDM-9 Pro
VIMAK DT-1000 It's a Transport CDM-9 Pro
CDM-9 pro with broken ribbon/flex cables for both laser and motor - what possibility for repair are there ?
Thank you for advices.
What about this approach for reconnect torn flex leads like to find underCDM-9 pro with broken ribbon/flex cables for both laser and motor - what possibility for repair are there ?
The almost complete Philips CDM range of CD Mechanisms | HFA - The Independent Source for Audio Equipment Reviews
go to
FIX FLEX CABLE - YouTube
Links are death - often usual after several years.Both CDM9 (normal motor) and CDM9pro (brushless motor) was the first mechanism, where is in use a so called LDGU (hologram laser diode) from Sharp instead a normal laser diode. The reliability of this diode is significantly worse than by normal laser diode. What you have described is exactly the same fact, that I observe, if there is a bad LDGU by my service work.
HTTP 301 This page has been moved
Multi-element grating beam splitter with a reflection grating element for use in front facet substraction
about
用PHILIPS无刷马达和金属托盘升级CDM9摇臂机芯_jjjjjj1_新浪博客
the first both I have save and will upload here. But the last both are even no longer available under Wayback Machine
Maybe one of the members have save the images and can upload here
- Digital Source
- CDM9 Pro
