This project started after reading about and finally building Art Welter’s Keystone sub (thank you Art and thank you all for a great read!). The simulations and measurements suggested one Keystone sub would be about as loud as 2 BFM T48’s in half the pack space. Having built 2 at 21” wide and going by ear (outside SPL measurements are difficult for me, but I hope to be able to do some measurements this summer) I would say that is about right.
So now I am tempted to scrap/sell the T48’s and reuse the 3015LF’s (old version) in a more compact design. I have read the SS15 thread and as much info I could find on Martinson’s THAM15, but my urge for DIY keeps nagging me so I started thinking about a new design.
As the title says, I am trying to come up with a (relatively?) compact design, compact in packing space that is. So I drew up this:
[image]Image:Compact Cheater Sub FLH B 03|none[/image]
Using a triangular form it’s possible to reduce packing space by using the room inside the horn. The speaker can be tucked away inside the horn of the 2nd speaker for transport. This means this design needs to be built in pairs, but that already was my intention. With two cabinets you can easily “V-plate”, like the t48 more or less demands, and “cheat” your way into a bigger horn without needing the complete woodworks and space. So that’s “cheating” part of this design. See the configuration on the right in the image above.
I know my SketchUp skills are pretty much non existing, but I hope I got the basic idea across. Now for the fun part: Hornresp. I did some sims and thought this would be quite acceptable (if feasible):
[image]Compact Cheater Sub FLH B 02a|none[/image]
[image]Compact Cheater Sub FLH B 01a|none[/image]
I know, this is the sim for a FLH and the SketchUp image shows a TH, but it's just to show my idea...
Genuine 40Hz reproduction at 135dB with 450 Watts for each cab (so 900W into 4 Ohms total). The difficulty for me is translating the Hornresp data into a physical design. I more or less guesstimated the dimensions and I hope I’m not too far of. It looks like an easy build as well, with only one fold. But to be honest I haven’t calculated the areas yet. These are just the first thoughts I had...
