Cathode bypass cap ?
plate resistance
Yes, the effective tube plate resistance goes way up. Add another (u + 1) * Rk ohms to the "stated" value.
For example, a 12AX7 at 1mA, 150V will have an rp of about 60k. If the common cathode amplifier stage uses a 1k ohm Rk, then add another 101k for a total effective rp of 161k.
The bypass caps preserve gain and keep the output impedance lower. But often at the expense of sound.
www.hagtech.com
