Hey all, I have a Carver M1.5T that blows fuses, and appears to have two output devices (Q1, Q2) on same board with shorts...
Weird thing is I downloaded the schematic and it says Q1,Q2, Q4, is MJ15023 and Q6, Q7, Q9 are MJ15024.
Board is 20032-3
But mine is Q1, Q2, Q4 is Motorola C10000, and Q6, Q7, Q9 is Motorola C11000...
Any ideas? Can I just replace the two bad Q1/ Q2 with MJ15023 and be OK, or should I stay with Motorola C10000? Saw one guy on ebay with C10000, but can't seem to find any info on them at all... any advice??
Board is 20032-3
Are you sure those are not just Carver part numbers on the transistors? C as in Carver makes me think so. I have never seen Moto C10000 or 11000 as a part. A lot of companies buy their parts marked with house numbers instead of genertic type numbers.
If it were mine, I'd be sticking the MJ types in there.
Use the MJ15024/25 pair if available.
Early M400s used the MJ15015/16 and frequently puked, replace with the MJ15024/25.
OK, now I feel like a dope. Why did I not think of that?
The schematic from the service manual is very hard to read - is it MJ15023/24 or MJ15024/25?
The 22/24 are the same die, the 24s are test selected for the higher breakdown voltage specification.
Same story for the 23/25.
- Carver M1.5t Output Devices...
