Here's my query...
I bought a pair of Gale 4 floorstanders on eBay a while ago, they were local and cheap and I wanted to give floorstanders a go to see what they offer over my Mission M71 standmounts...
A bit of investigation led me to believe the woofer cones were a bit wonky... buzzing at medium to high volumes, but no visible tears. So I believe they are useless.
Gale 4's had a Vifa D19 tweeters, nice crisp high trebles and Peerless (India) SKO-130 5.25" woofers.
I've decided to experiment on the Gales. I live in the UK and getting cheap decent drivers is not all that easy, and I don't want to shell alot out on what is just experimenting with a £30 pair of floorstanders...
I've started looking to car speakers, I can get a pair of Pioneer car speakers on eBay for £19.99 with free postage... http://www.pioneer.eu/eur/products/archive/TS-G1349/index.html
Is there any reason these, if I could get them in the cabinets would sounds awful, not drive properly from a hi-fi amp, or just generally be a stupid idea. They almost seem like a good idea what with the woofer and tweeter driving from the same spot (like a very poor mans Dual Concentric Tannoy lol!)
There are cheap 5.25" Skytronic woofers on ebay UK, but mentions on here seem to write them off...
Any advice from anyone to a newbie?
Cheap coaxial car speakers are nothing like Tannoys btw. You probably wouldn't like the result, and it's very unlikely that whatever cabinets you currently have would work optimally with these Pioneers. They're also probably 4 ohms, which is something to consider. And I certainly hope you weren't planning on using those Vifa tweeters with anything else you put in there, or the passive crossovers.
On the other hand, people throw together cheap stuff all the time and end up fairly satisfied with the result, especially considering the low cost and labor involved. Just look around in the full range section. There's obviously some fun to be had in it. But if you're gonna do it, do it right.
car speakers in small PA
I use JBL GTO937 6x9" (2ohm) car speakers as both front of house and for foldback (mid-high) with my mobile party rig. They were dirt cheap in comparison to buying pro-audio drivers and are very efficient (95db), they will also take a pounding. Usually, you can buy cheap 6x9" boxes for them in the same car audio shops.
I am using a Tripath powered amp that likes low impedance loads, so the speakers match very well.
http://pix.minirig.org.au/main.php?g2_itemId=661
col.
col.
Thanks for both your replies, I was expecting to be merely laughed at and shrugged off!
I know they are not the ideal, and that they are nothing like as Tannoy DCs! Hence my slight sarcasm (which doesn't really translate on the net lol) in calling them the very poor mans DCs 😉
Bit of research later, they are indeed 4 ohms, 89dB sensitivity, not the best eh... 4 ohms and 89dB... is that a bloody hard drive for your average 30-40W hi-fi amp?
But, the reason that I'm looking into this path is that the Kenwood speakers in my car seem to give out fair more detail and better tonal balance than any of my current hi-fi speakers... They're mounted in a car door, how on this earth can they sound better... but, they do.
Which must mean my home speakers are BAD! (Mission M71, JPW mini monitors which have the same SKO-130 woofers as the Gales)
Got my fingers crossed for a pair of Tannoy Eyris 2s I've very nearly got my hands on!
So, of course using something like the Pioneers means straight to amp connection (no crossover) and disabling the Vifa (two tweeters, no thanks lol) And then the cabinet problems... to be honest the original woofers didn't seem optimal for it anyway so perhaps there might be an improvement, but that's down to pure and sheer luck if it works that way!
The other 'budget' options I've come across are:
http://cgi.ebay.co.uk/Skytronic-902...14&_trkparms=72:1301|66:2|65:12|39:1|240:1318
http://cgi.ebay.co.uk/902-420-5-25-...14&_trkparms=72:1301|66:2|65:12|39:1|240:1318
Have read nothing but bad opinions on here about Skytronic stuff though!
This is all quite new to me, but I'm loving learning what can be done to improve and tweak things from speaker crossovers to Marantz's modable CD player... (more my thing than building from scratch)
Re: car speakers in small PA
Careful with car component specs. As I suspected that is the sensitivity with 2.83v, which correlates to 1W at 8 ohms. At 2 ohms the sensitivity goes down from the quoted 94db to a more typical 88db.
col said:I use JBL GTO937 6x9" (2ohm) car speakers as both front of house and for foldback (mid-high) with my mobile party rig. They were dirt cheap in comparison to buying pro-audio drivers and are very efficient (95db),
Re: Re: car speakers in small PA
Could you shed a tiny bit more light on this, I don't have my electronic engineer mate to explain the above to me lol
Ok,
Power is voltage*current. Current is voltage/resistance (or impedance at AC).
It fits that 2.83v/2 ohms = 1.415A * 2.83v = 4W. So at 2.83v the 2 ohm driver is getting 4W, and the 8 ohm will get just 1W (the standard).
Every doubling of power equals 3db output increase. 4 is two doublings of power and hence a 6db increase in output. Working backwards the driver is defined as 94dB (2.83v), minus 6db so 88dB (1W).
Hi Dr.EM - thanks for doing the math. I was aware of the sensitivity/impedance issue but I guess the marketing hype got me on that one 🙄 I'm crossing over at 160hz into my subs though (2 x JBL SB-2) and seeing I'm using 4 of the GTO937 they seem to be plenty loud, easily louder than the subs if I let them. The interesting thing with the GTO937 is how flat they are across the frequency range, and they actually do sound very nice, as long as I don't let them do any sub-bass 😉 They are also very small and compact, leaving more room in the car for other stuff when I transport the system.
col.
col.
Col, is there any particular reason why you have chosen the three way instead of two way (GTO927)?
I was once really surprised by Magnat car speakers in an airport bus. They sounded really fine, so I would like to use a pair in some kind of mini monitor / OB + seled bass setup. 6x9 has the largest moving surface, right?
I king of like your MicroDoof system. Why is the section on your website password protected? I would like to read more🙂
My idea is to use a 4 channell car amplifier with an active crossover built in - powered by a sealed UPS battery. If I use a power adaptor / charger with nominal 10 % current capacity, then the battery should not get too much discharged while listening.
pelanj said:is there any particular reason why you have chosen the three way instead of two way (GTO927)?
Is there any reason why you've choosen a 3-way over a 1-way? One of the best sounding 6x9s for home use is the GM/Delco 10 ohm (the 4 ohm one is almost as good)... you run across these in boot sales over here fairly often for $2-10 and every time i leave with a wicked grin on my face knowing someone swapped these out for a horid set of Jensen TriAxials (or similar)
If you find a big 1-way to not quite cut it for you in the top-end that 19mm Vifa is quite a nice tweeter crossed up high.
I was actually considering using a two way. A fullrange unit is also an option, but the quality stuff is hard to get here. I do not know about the JBLs, but the Magnats were quite a big surprise in terms of sound quality.
The two way wasn't available here, also the 3-way was on special. I got a pair of them for AU$100.
pelanj, don't worry about the protected area of the website. That was just for the secret location to a party that we did in the bush.
You can find other information about the components in my MicroDoof 2008 system via the main web address.
planet10, what size enclosure do those fullrange GM/Delco require? I haven't seen anything like that here. I think Moondog probably has a shed full of them though 😀
col.
Pelanj, If you are handy with a soldering iron look at the 41hz.com amp9. Car amps are very inefficient and spend most of there energy putting heat into the heatsinks. Not good for a battery system that isn't being constantly recharged. If you get a class D or T amp like the amp9 they are usually 90 percent efficient, so last longer on batteries.
col.
ROFLMAO
Hi Col, no I don't have any of those, was that you who purchased the other set of Kaltros on ebay??
i do have a nice pair of DickSmith full range here tho if you are interested 8inch curvilinear paper with wizzer, they need some work with some of the tricks Daves given us like damping the frame and bog around the magnet but quite nice.
Some car drivers are better than others, never met a woofer I didn't like
Ted
Ted
Col,
I do not need to get all the output power and the battery will get recharged, it should supply only for the power peaks, functioning as a sort of "megacapacitor", a 4A 13,8V PSU with a 6-10 Ah UPS-type battery should be able to power a car amp up to 4x75 W. One can get also Class D car amps. I will most probably start with a used four channel low power amp - or maybe I will be lucky and will find some ready made T-amps for sale here. I can put together an amp (did that more than once🙂 ) but my metal working skills and tools are very limited - i need to bother someone to build a case for me.
col said:planet10, what size enclosure do those fullrange GM/Delco require? I haven't seen anything like that here.
The 10 ohm ones open baffle or big as you can live with aperiodic. The 4 ohm ones are more suited to a box.
These were made in the US for GM cars, so are probably rare outside of North America. They were just an example of a good one.
dave
I had some Indonesian 12" "Audax" fullrange that were very nice, had the little wizzer thing too. huge magnets on them, rated at 100W 8ohm. I wish I had tried them open baffle. I had them in a sealed box with a 3-way crossover, a two way would have probably done the trick.
There is a picture of them here:
http://minirig.org.au/minirig-v3/
I think it is still possible to get these brand new in Indonesia. They have this whole range of mass produced audio stuff that doesn't get exported. Most of it is copies, like China but just for the local market.
http://www.minihub.org/~colren/trips/et10-03/cheapindotronics/
col.
col.
- Car speakers in the home??!
