I can convert the built-in internal SMPS of DCX2496 and DEQ2496 for 12V operation, preserving low EMI and line isolation from original unit and featuring 'remote' turn-on and 8V to 16V input voltage range.
This is the PCB fixture for the primary side. It replaces a section of the original PCB and has the same size, so no machining is required.
This is the almost-finished SMPS after primary side replacement and transformer rewinding.
Bad news is that shipping between Spain and USA may cost more than the equipment itself, and transferring currency is a mess, but I'd do it anyway for a reasonable price.
www.altomobile.com
the ucs pro seems very similar to the dcx. emailed the distributor and got a quick reply.
you cna always use a parametric EQ; the Behringer Feedback Destroyer (BFD) is quite popular. I'm not sure if you can "lower" the frequencies on a Behringer digital EQ unit to make it a "subwoofer" EQ or not - I'm not familiar with the rest of the Behringer family. There is always the DIY solution. I have a construction article around here somewhere about making your own subwoofer EQ, but it's labor-intensive. It's a project of the "make this circuit, then repeat 29 more times with the capacitor values from the table" type.
Eva said:I can convert the built-in internal SMPS of DCX2496 and DEQ2496 for 12V operation, preserving low EMI and line isolation from original unit and featuring 'remote' turn-on and 8V to 16V input voltage range.
Hola!
Eva, podrias darme tu email? Tengo mucho que preguntarte.
Un saludo!
El mio es dondhgARROBAterra.es
Espero tu respuesta
- General Interest
- Car Audio
- car auto eq
