Well, I got my inductor problem out of the way (used thinner wire), but I've still got some questions on which capacitors to use. I've read that with 2nd order xovers non-polar capacitors are prefered, but what about 1st order (3-way 1st oder is what I'll be using)? Can polar ones be used? What about voltages that the capacitors are rated at? Is the higher the better? Does it have to do with the wattage being pumped through the speakers? If the speakers can handle 500w+ RMS (not that my amp can power that) what voltages for the caps should I use? Also, are polyester caps good for being used in an xover? Sorry for all the questions...
