I need a help selecting values for Rb(1-8) and Cin(1-8) and Cout(1-8) on my circuit. I'm pretty new to designing analogue circuits.
Unfortunately the forum wont let me post a picture (I need to have made more posts?), so I'll have to describe it.
The circuit is going to take audio from a mixing desk. I will be tapping into the "pre-fade output" which is just after the pre-amp for the mics. The level is too high for me recorder, so I need to attenuate it. I don't have specs for the output, but the manual says it's at "professional line level". As such, I intend to make a "copy" of the signal, using a TL071 Op Amp, and then attenuate the output.
There will be 8 mono audio channels - so 8 taps from the desk and 8 copies of the main part of the circuit.
I have plenty of TL071 Op Amps that I intend to run from a 12VDC source. I intend to use 1 per channel.
I intend to use a TLE2426CLP chip to provide a 6VDC bias for each signal into each TL071.
As far as I know, I only need one TLE2426CLP, but I need a resistor between the output and each + input on the TL071. I'm calling these Rb(1-8)... but I don't know what value I need for each. I'm assuming they'd all be the same.
Since I'm using a DC bias, I need a DC blocking cap between signal in and TL071 (I'm calling these Cin(1-8) ), and also on the output of the TL071 before output to the recorder (I'm calling these Cout(1-8) ).
I thought I had it figured out, as I was going to use a 1uF on Cin, and a 50k for Rb. According to the RC Calc I'm using, it says a cutoff just under 8Hz. However, when I looked to get the caps, apparently I need to use C0G and they don't seem to offer values that high, and I shouldn't use X7R for audio because they are noisy. That's where I'm stuck!
If I raise the Rb value enough so I can use a C0G (biggest value I can find is 10nF), this means using a 500k Rb. Is that going to be ok or is the impedance too high?
How will I overcome the problem with the output impedance? As far as I know, the recorder input impedance is 20k, which if I use the 10nF cap is going to be cutting off around 800Hz, which is totally unacceptable.
