SOrt of, adding a resistor there two will create a zobel network, this will flatten out the impedance curve that naturally rises due to the self inductance of the voice coil.
In a subwoofer I dont think this is worth doing the sub driver is directly driven by the amplifier yes?
The driver will also probably have a lowpass on it around 80hz or even less. The rise from self inductance will most probably be way past this frequency, so the amp will not even be driving the sub at frequencies where the impedance rises.
Do you mean something else?
