hi-i have just inherited a goldring 1012gx cartridge on an sme 3009 S2 improved fixed headshell arm, mounted on a thorens 160 super TT.
the cantilever seems to have been "pulled" toward the outer side of the platter, so that it sits in the cartridge at quite an angle. it is obviously pulled more near the beginning of a record than at the end, where the cantilever seems more centred.
i have checked alignment-i cannot move the arm any further forward on the deck using the appropriate adjustment screws (already at maximum), and the armboard has been drilled in the correct place according to the thorens template. normally, simply rotating the cartridge itself in the headshell would sort the problem, but this sme headshell, like most others i have seen, does not have mounting slots so i could do this-
do forumites have any ideas of what i can do to correct this misalignment propblem?!
many thanks
many thanks
