http://users.tpg.com.au/users/gradds/candles1.JPG
http://users.tpg.com.au/users/gradds/candles2.JPG
Not the design plinth, ran out of energy!!
Baffle is only tacked on, will be attached from rear once completed
These are designed as an mtm using the Vifa M11WG + D26NC. The m11's are the ones I got to complete "Gumby" til I could find the final P11WH's (which should arrive soon I hope).
I have to do something with the M11's!!
May consider rears and sub and try to sell them as a HT system.. we will see what happens !
Baffle will be veneered with some very nice Tassie Blackwood I have, stand will be semi-gloss black I think.
Pat.P said:Andy Those are looking good !What kind of drivers will go in these,are they going to lingt up?Pat.P
OOps Saw the drivers ,and are they going to light up (was in rush,between laundry and work)Pat.P
3 Hrs!!! It's taken me over a week to get my first of two MTM boxes to the gluing stage (and I've done not much else!!)!!! Admittedly there isn't too much more to do to get the other one done, and I was being very carefull, but I wish I had even a 1/4 of your speed!!!
Tony.
Tony.
wintermute said:3 Hrs!!! It's taken me over a week to get my first of two MTM boxes to the gluing stage (and I've done not much else!!)!!! Admittedly there isn't too much more to do to get the other one done, and I was being very carefull, but I wish I had even a 1/4 of your speed!!!
Tony.
They say that speed comes with experience but I've spent a load of hours building speakers and in actual fact I'd say I'm around the same sort of speed I was when I first started, maybe a tad faster but nothing to talk about.
What I have found is that I can do cuts much more accurately and intricate difficult boxes are trivial to cut and build once the cutting list is worked out.
I'd sooner trade speed anyday for skill. It looks like Andy has managed both.
You're more looney than me Andy.... not by much.
It was good to meet and to have a listen to some of Andy's creations and music and to see the Coneheads (they'll always be that to me) in progress. Someday Andy will come over an listen to my stuff.
I know Andy's secret for quick construction. He just yells at the MDF dust on the floor and they go into formation creating all these wild shapes.... you don't think that anyone could actually have the talent to create this stuff do you?
I think I saw it on an episode of The Twilight Zone.
Newcastle DIY society
Just need Collo to chime in now.
barfind
Did you ever finish the AKSA?
barfind
rabbitz said:
Newcastle DIY societyJust need Collo to chime in now.
barfind
Na, just bought a 300b set instead. I can bring it over for listen if you like. We should all get together for a meet. Lets organize it OK.
Nigel
from what I've noticed I'm actually getting faster... as I suspect you are
but as you advance you want to go more intricate with the designs so therefore it takes LONGER even though you're actually faster
my bass cabinets for instance I did very fast... but it still took me around 45 hrs just to get those cut sanded and glued... maybe more like 60 hrs
and that actually is about twice as fast as I could have done that 3 yrs ago...
Audiophilenoob said:but as you advance you want to go more intricate with the designs so therefore it takes LONGER even though you're actually faster
Now that's certainly true.
I think I've got some mild form of OCD though because I measure everything around 3 times before I even think of looking at the saw.
Its quite funny since I just get it to cutting bench and then I still have to measure it one last time, my tape measure is certainly the most important bit kit I've got and it only cost me a tenner
I still make mistakes though and that's usually because I haven't wrote the damn sizes down correct in the first place
I still make mistakes though and that's usually because I haven't wrote the damn sizes down correct in the first place![]()
Hehehe sounds like me, though I not only do all that, but also cut a test one too!!!
I made a bad mistake yesterday, I was keen to get the second box together and just after I finally had it all glued and clamped (took me about an hour, so the first joints were well and truely stuck) I realised I hadn't put in (or even drilled out the bigger holes for) my tnuts (actually just normal nuts forced into slightly smaller holes)...... should be fixable though
Tony.
Nigel
I'll send you a PM tonight. BTW... what's the 300b?
Valvemark . But it has been highly modded now. It has choked power supply and chocked output trannies. About 20kg of iron so its going to a long time to break in. Starting to sound pretty good with about 30 hours on it.
Nigel
Andy Graddon said:mid term Uni break is 24th Sept to 9th Oct !
would be reasonable for me.
Cool, I will put that in my diary. What about you rabbitz?
Nigel
- Candles....Not too bad for 3hrs work !
