Can you help me identify these burned resistors?
I have opened my Chinese made amps (I have like 5 of them) and I discovered two burned-looking resistors. The amps work without any problem so far.
# First one - Fatman 182 (rebranded Dared MP-15)
I have the schematic of Dared MP-15 (attached). It's is R12 and the schematic says 51k 2w.
A friend which is assisting me with it recommended to replace it with one that can handle more power. Should I buy then a 51k 5w to replace it?
# Second one - Fatman 252 (rebranded Dared MP-60)
Unluckily I don't have a schematic and seem to not have luck finding one (see below). It's R34. It's pretty brownish so I'm not sure it's recognizable anymore by the color bands.
Can you recognize it? What would you recommend me to do?
# Why I did not manage to find Fatman 252 schematics
Fatman closed down business years ago. TLaudio, which also distributed some Fatman, does not service these amps, only premium Fatman products.
Dared US does not have schematic for MP-60 and told to contact Dared China.
Dared HK says MP-60 is not from them, but a copy from Dared China and they are not authorized to talk to each other (?).
Apparently there was another branch of Dared in mainland China, assembling some variants of these amps. I've tried contacting them, but no success so far.
For the R12, from the mild burnt seen, it may reached more than 1W, maybe you should check 6N3 tube current see if they're balance or not, and mains supply voltage not >120-130V instead of 115V?
For the burned R34, I actually have another identical amp with an healthy R34.
Can you help me confirm its value by the color?
I see Yellow - Brown - Red - Gold:
41 x 100 = 4.1k ohm 5%
Or do you think that's a violet?
