(By the way, this is not a general question, I want to learn if I can use polarized capacitors instead of non-polarized caps for this circuit.)
I know that using better caps are always good so I have bought some expensive auricap capacitors for the vacuum tube pedal I am building. But when they have arrived I have figured out that the caps are polarized. On the schematics, the original caps are non-polarised, so I want to ask if I can use polarised ones instead of non-polarised caps. (If I can, which way I should connect them)
The caps are 0.1 uF and here is the schematics. I have circled that caps in yellow...
[IMGDEAD]https://www.emre.co.uk/wp-content/uploads/2016/06/caps.png[/IMGDEAD]
Thanks for help...
Thanks for help...
