Can i use one of these transformers?
These are not in the European catalogue (as I remenber)...
The insulation transformers are as "good" as all other standard transformers, an you can use the for your Power Amplifier...
However you will need two (one for positive and one for negative rail) which gives you app. +/- 155 on the rail......
THAT IS AN AMAZING AMP 😉
Arnt they? Oh...
Yep 😀 if im going to make an SS amp, im going to do it properly. 😎
