I have a 2 x 6sn7 preamp that has a bad VC. The original is a Noble brand, that has worked well and I found another Noble that is the same size except it is 50K. Would there be much of a change for the different value VC? I don't want to go through all the trouble of installation as it is a tight fit. Thank you for your suggestions. cheers, 808
