WARNING: Tube/Valve amplifiers use potentially LETHAL HIGH VOLTAGES.
Getting ready to finish an amp project I've had on the shelve for 5 years now and just ordered Electro-print plate chokes with bell ends. Can I mount them next to the OPTs without issue???
I heard back from Jack at Electra-print. He said the same. The OPT is not the issue it is the PTX and filter chokes.....which in this case will be on the other side of the Plate Choke.
I will mount the PC under the chassis and away from all the power.
