Can I bridge TDA7388
Hello.
Almost all car audio amplifier are already bridged.
This amp is already bridged, so you cannot.
You can use TDA7560, it's more powerfull and accept 2 ohms.
Also,you can use step up converter power supply for 18V instead 12V.
I have smps from car amplifier. It has 2 x 25A fuses so... 2 x 25A x 14V = 700W (I know that this is not 100% accurate, let`s say 500w to be safe 🙂).
It has 27-0-27 output (so it`s positive and negative supply), this was measured with 12V input.
What are the ICs that would give me the most power on 27-0-27 supply at 4ohm load, mono?
I would like to build car subwoofer amplifier so high THD is not a problem.
I am searching myself, but didn`t find anything good sofar, because most of powerful ICs are using higher supply voltages... I`m aiming for about 200rms @4ohm is possible...?
