can cap - rectifier spacing
If you put metal next to a hot valve, blacken the side facing the valve so that it absorbs heat and does not reflect it back into the valve. Keep the side facing the capacitor shiny, so that it does not radiate too much. Ensure there is a good heat conduction path into the chassis (to keep the metal cool) - but then you have to keep the conducted heat away from the cap.
A bit of space is better! Just make sure the leads to the rectifier don't spray buzz around from magnetic induction.
How is a cylindrical object (the cap can) going to reflect heat (in any significant quantity) back to the source of heat (the rectifier) which itself is cylindrical and will itself reflect off a large proportion of any heat radiated from a line source toward it???
I think an inch (or even better, 25.4mm) would be ok, more is better. But more for the sake of the capacitor than the rectifier.
Holes won't much affect radiation, which is significant for a power valve like a rectifier. They will reduce the glass temperature a little, which will reduce heat radiation from the glass itself but do nothing about the heat coming straight from the anode through the glass.
I wasn't talking about the cap can, but the metal screen. Incidentally, why do JJ cover their cans in black - about the worst possible thing to do. Do they assume we all use SS rectifiers?
I would leave a couple of inches gap as a minimum.
Moderator
Joined 2004
<snip>
I'll second all of that - for me 2" is the minimum for GT style envelopes, for bigger G types I generally allow even more. The components inside doing all of that radiating are generally in a well defined plane and do a better job of heating things nearby than you would think from the shape of the envelope.
yeah, I am with Kevin. 1/2" is definitely not enough. 2" would be good.
holes in the chassis around the rectifier only help if there is cool air down there. If there are power resistors down there then you have just made the problem worse. Helps for the resistors though.
