Can be fixed?
Hi!,
I've been reading the forum for a while... and decided to give it a try...
I strip the LCD and everything was Ok... I had image. (It is a Innovatek 007VG 7")
Then I though if I rip off some sort of filter it would be ok.. but I was wrong... after I rip off I have no image... when I turn on the LCD all the dots (pixels) change from transparent to dark transparent
For what I read I rip off a polarizer filter.. Am I right?
Is there any way I can fix the LCD?
Sr. C.
you may have torn the connections for the signal cables to the panel, or any of the other connections. Check very carefully, with a magnifier if possible, to see that all connectors and conductors are intact.
It is also possible that you generated a static field that killed the electronics...
