I had a dual xia2460 and had a hard time driving it to clipping with a old HU that I think is 2v, iirc I could not. Very few other amps have I run into this. Back then I was just testing on subs and not measuring, but there was a significant difference; full gain didn't give me much output. Some models of the brands from power acoustic would gain so high I got feedback with them, not sure why other than maybe 20% on the HU would clip them and that was very unusual. The RCA on the HU are actually grounded through a fuse to the PS so I know it was shielded properly. (from the point internally that they ground as I blew that up, so I ran wire to an external fuse)
Another issue I see with cheaper to mid amps is when they have an adjustable bass boost they often have less gain, but not true of all of them. Note some even have the remote run the boost and not the gain. I have a mrd-m500 alpine which I would consider middle of the road and not a junk amp, I have the gain set to max in my car. I don't use the boost as I have a 16 band EQ and sub level in the HU with 5v preout, but sometimes on CDs and certain radio I have to run the sub level to near max on the HU to get good output....which seems odd. It is running at 2 ohms also though I doubt I am using even half its output in normal use it typically shows under 10A draw. The subs are IB 15s, they don't need much power to make thump and are only in there to get under 30Hz with no box. On a boosted bass CD they go really loud/low so it is certainly capable of sufficient output. While another amp will gain higher, I'm considering a bass processor if it can help control the various level issues I am getting or at least a remote level. I can turn the other amps down, but am close to max volume on the HU now for some sources.
ATM the highs are only 50rms/ch so I would consider it an issue, but I do have other amps to try. This has nice readouts for temp/voltage/amperage/etc is why I wanted to run it for a while.
All that said I ran 2v HU until a few years ago in many systems and never had an issue with noise or enough output or ability to clip the amps. Had I ran into just the right amps I may have, but line drivers are not needed in typical systems IMHO.
