NAP 160
The JRC 450 seems to be a Jerrold convertor part. Check http://tamago.mtk.nao.ac.jp/tama/recom/general_lib/circuits/010720_matrix/mat4a01.pdf for information on the OP-27G. It seems like a front coil driver.
Morsel
Its nice to see you around again. Its was so long since I've read any of your posts that I thought you may have decided to rest on your laurels.
Morsel
That probably explains why I haven't heard much of you. I'm in the middle of building one of these Alephs and this forum has had all of my attention. Headwize is just a memory and you were prominent in that memory. BTW, I built your headphone amp (or should I say the one you contributed to) for a family relation and I've been told it gets lots of use so I guess a thanks is in order. I have also been preoccupied with my "Audio Power Theory" so Headwize has had to suffer my absence. I'm sure with you there they will be able to get over the loss
