Hello All
My first time here. If anyone has a suggestion it would be much appreciated: I have a Azur 640C CD player which manifests odd problems now and then, and seems to be heat related. The CD will not load and after much whirring and the laser moving back and forth the message "no play" appears. The open /close button also does not work now and then, but the remote does work.
The Gold "box" labeled "precision servo control" is hot even when on standby. If I unplug and allow it to cool down for a few hours it works fine for a while for up to 3 CD or 45min continuously which is odd.
Any ideas the unit is about 4 years old ??
Many Thanks
Many Thanks
Get a can of freeze spray from Dick Smith. Wait until the player starts "playing-up", STOP THE PLAYER, and then cool down the suspect part. See if you get it working for another 45min or so...
Boky
edit: are there any Dick Smith stores in NZ?
Boky
Extreme_Boky said:Get a can of freeze spray from Dick Smith. Wait until the player starts "playing-up", STOP THE PLAYER, and then cool down the suspect part. See if you get it working for another 45min or so...
Boky
Thanks I'll try that. yes we have DSE here, great forum this BTW !
