Cambridge Audio 851A or 851W schematic anyone? Looking for just the amplifier board schematic for either one of these amplifies.
Being recent models, the chance of even getting a peek at a schematic is very slim. Even service agents will need access codes to the encrypted tech. details so unless they want a lawsuit for breaching confidentiality agreements, they won't be sharing schematics either - for quite a few years, I'd guess. 😉
Well, that really sucks. Would just like to know what the changes are between the 840A V2 amp and the newer model, if any.
Know they switched to chip for volume control rather than relays and such, but just want to know what changed on the one PCB. Oh well.
Regards,
Greg
Regards,
Greg
Hello Old'n'Cranky,
Sorry, but already looked there. There have the user manual, but no service manual or schematic in any form. Thanks for the suggestion anyway.
Regards,
Greg
Regards,
Greg
Bugga.
Sorry.
If it's any consolation, CA are a brand best avoided anyway.
Why's that?
Try repairing one.
The design, construction, and materials used are all, unpleasant.
Very few repairers want anything to do with them.
They don't reply to emails.
Better still, have a look at all the forums and threads of their many failures.
Seems anything designed/sold by 'audio partners' is a migraine in the waiting.
Try repairing one.
Sounds like they're best avoided then.
Rubbish. The higher end CA amps are designed by Doug Self, one of the most experienced and respected audio designers in the world.
I should clarify, I'm not against the circuit design.
Although their are some rather silly choices made there.
It's the assembly design that sucks.
makes it very service unfreindly.
really cheap fibreglass boards that flex and also shrink with heat.
plate throughs that shear.
very poorly soldered.
have to undo and move multiple boards to get limited access to other boards.
have a read through some of the service manuals.
to flash the pic's you need to modify cables.
volume control issues that are mentioned as needing to be modified.
the whole thing just reeks of half hearted effort.
But I still suggest you go looking for postings about faults.
I have one unit here that other repairers can't fix, and I'm about to bin it as well.
I have another 2 units on there way to me, both have been rejected by two other repairers already.
And I know of three other repair shops that will have nothing to do with them due to the issues involved in service or repair.
That really inspires confidence in the brand doesn't it.
All the more reason to leave it on 24/7 to reduce thermal cycling/stress.
Designer
Doug Self did design the 840 A & W from what I am told and came up with the Class XD design for the output stages as well.
But, the amps above the 840A like the 840A V2 and numerically up were heavily changed from his design before they were produced. Seems someone decided they could do better and while they kept the XD crossover design, the rest is quite different. Good or bad, only the 840A & W were as designed by him.
- Cambridge Audio 851A or 851W schematic anyone?
