I just went overboard and built 2 massive cabinets 4x2x2 completely disregarding the math since the purpose is to house a plethora of tweeters and 2 aluminum cone 15's. Huge and loud for the sake of P.A. use.
I'm not sure about bracing though. So far I've conceived just adding a rib cage skeletal like structure before installing my insulation material. Here's a hard draft of the design.
[IMGDEAD]http://i56.tinypic.com/2woac0m.jpg[/IMGDEAD]
I'll likely add vertical beams to the rear/side corner seams as well.
I had thought about placing some cross beams horizontally but, really don't want to divide the sound waves. The weight is also crazy enough anyway. There is a 3 inch vent at the top and bottom of the speaker baffle. Does anyone have preferences for bracing their loud speakers?
I've seen a lot of really amazing designs as well as crude internal builds where several 2x4's are just bridged across and through the center of the cabinet. I'm avoiding braces that will create ducts and sound wave dividing and will only implement such if there's too much noise or boom.
