Hello,
is it important to use bulbs with 120 Volts or may I use 230 Volt bulbs, too?
E.g. when using a 300 Watt bulb and a 60 Volt rail the current is 5 amps und it doesn´t matter if i use 120 Volt or 230 Volt lamps.
Isn´t it?
m.f.G.
Günter
Isn´t it?
m.f.G.
Günter
Gunter
You can use 230V bulbs but the wattage will need to be four times higher. See the previous thread that I started on this topic:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=1400&highlight=zenlightenment
Geoff
Geoff
