I finished the Pearl last night. It sounds great, but there are some bugs I still need to work out, and I'm in way over my depth here. I'd really appreciate it if someone could help me out. I'll put down the facts that seem relavant to me, and if I leave out something important, please let me know.
* I built the Pearl almost exactly to instructions. I braided the umbilical from the power supply to the main chassis (mostly for mechanical strength), in case that's an issue. The umbilical has 5 wires, the 5th connects chassis ground of the two enclosures. PS and signal outputs join at the chassis ground of the main enclosure, then go back to the PS enclosure through this 5th wire (I plan to experiment with this to see what gives the least hum).
* My linestage is a transformer-based passive. The input impedance at DC measures around 60 ohms.
* DC voltages check out, mostly. All the numbers marked on the PCB are within 5% except for the 11.7V, which is 10.7V for me.
* Wiring dress - power supply wires inside the main enclosure are twisted and zip-tied close to the chassis. Signal wires are pretty much direct from solder pad to RCA.
* My Pearl is picking up a radio station. This, obviously, is RFI. I've never had RFI problems with a phono stage before.
* Along with the radio station, there's a squealing or howling sound. This changes in frequency by itself sometimes. It changes drastically if I touch or move either of the input wires (RCA to PCB).
* I don't have a 'scope, but I think I can hear some distortion. Bass transients at high volume definitely distort.
* It's built in a basic Hammond aluminum box, the top cover is currently off, and the box has holes in the corners (i.e. isn't fully enclosed). Placing the cover on the box didn't make much of a difference to the problem.
* If I turn the volume down and touch the input RCA on one channel, there's a 'pop', and the squealing stops. Any further movement of the input cable doesn't bring the squealing back, and the obvious distortion on bass attacks also disappears.
* On the other channel, the RCA connector pops every time I touch it. The squealing goes away on this channel too, but the noise floor is higher (this channel has an LED on it, so I'll investigate the noise floor later).
* Everything runs more or less fine until I disconnect the Pearl, solder something in and plug it in again, then the squealing is back until I touch the RCA and make it pop.
Those are all the observations I can think of. Questions:
* Is all of this RFI? Should I just use shielded input cables, and that'll solve all my problems? Or is something oscillating, which would then probably be a much bigger problem, I guess.
* There's an output coupling cap, so the near-short at DC that my linestage presents shouldn't be a problem, right? (With a previous phono stage my woofers started pumping the moment I'd select the phono input on the linestage). I tried a 200 ohm and a 5 Kohm resistor in series with the output, but that didn't seem to make much difference, maybe the squealing went down a little bit.
* Can a bad solder joint cause RFI pickup?
* I can't think of much else. I guess I could take it in to work and borrow a 'scope from one of the hardware labs, but I really wouldn't know what to look for.
Any help would be most appreciated. This is the first component I've tried to build that didn't come with parts and connect-the-dots instructions, and it's a little frustrating to be thrown into the deep end like this
Thanks a lot,
Saurav
Thanks a lot,
Saurav
