Built my first project after 20 year without doing much soldering and finished the Bugle 2 this afternoon. It plays musiv and sounds ok apart from a huge cannel misbalance, will this be a resistor probem or should I look elsewhere first? My soldering skills are poor, to say the least, so could a dry joint be the issue?
Any pointers in tracking this down would be appreciated
I'm no expert, but try checking that you used the same resistor combinations on both channels - the ones that control the gain. (40, 50, 60 dB)
