I'm using a Buffalo IIISE fed via i2s. The file is an original DSD download and not some SACD rip. The source is a USB to i2s converter with i2s and DSD multiplexed. When I start playback I get a nasty POP sound. I asked a friend who knows a lot about the Sabre32 chips and he provided the following.
"The buffalo has an 8ch DAC that is configured to be 2ch on the outputs via the pcb board. The problem is that the input routing needs to be different for DSD than PCM. When going to DSD, you have to feed the signal into at least 3 of the inputs which you don't have available on the buffalo unless you lift legs and solder wires. As it is now, 4chs worth of DACs are floating with no input. The noises you hear is a side effect of the working DACs being tied to the other dead DACs. Beyond this correction needed, the software into the DAC needs to be told to source the DACs for channels 5-8 to be different than default."
Russ, can you provide additional insight?
