I am designing one active surround sound system. Delay circuit is required to be added. For that i require BBD IC. I need the IC which is presently available.
Mahendra Palesha
Mahendra Palesha
Hi!
Try this ones:
NTE1641
Integrated Circuit
1024 Stage BBD for Audio Signal Delays
Description:
The NTE1641 is a 1024¨Cstage long delay low noise BBD that provides a signal delay of up to
51.2msec. This device is suitable for use as the reverberation effect of an electronic musical instrument,
or in stereo equipment, due to its long delay times.
Features:
- Variable delay time of audio signal: 5.12ms to 51.2ms.
- Clock component cancellation capability.
- No insertion loss: Li = 0dB typ.
- Wide dynamic range: S/N ≅ 80dB typ.
- Wide frequency response: fi ¡Ü 12kHZ.
- Low distortion: THD = 0.5% typ. (Vi = 0.78Vrms)
- Clock frequency range: 10 to 100kHZ.
- P channel silicon gate process.
- 8¨CLead DIP plastic package.
and
NTE1639
Integrated Circuit
CMOS Clock Generator/Driver for BBDs
Description:
The NTE1639 is a CMOS LSI Clock Generator ina 8¨CLead DIP type package capable of generating
two phase clock signals of low output impedance for use as a BBD driver. The built¨Cin VGG power
supply circuit provides the proper voltages needed for driving BBDs such as the NTE1641.
Features:
- BBD Direct Driving Capability of up to two BBD¡¯s
- Self and Separate Oscillations.
- Two Phase Clock Output (Duty: 1/2)
- Built¨Cin VGG Voltage Generator for Driving the NTE1641 BBD.
- Single Power Supply: ¨C8V to ¨C16V.
Aplications:
- BBD Clock Generator/Driver.
They work together.
You will find them at www.nteinc.com
I can put here the datasheets.
Best regards
Pedro Nuno Martins, aka sapito
Try this ones:
NTE1641
Integrated Circuit
Description:
Features:
and
NTE1639
Integrated Circuit
Description:
Features:
Aplications:
They work together.
Best regards
Please, download the NTE1639 and NTE1641 datasheets (they are in PDF format).
Ok, in ZIP format 😀
Ok, in ZIP format 😀
reverb unit
WHERE CAN I GET A CIRCUIT DESIGN FOR A REVERBERATION UNIT USING THESE CHIPS?
IT IS FOR USE WITH PHONO INPUT AND OUTPUT.
THANKS
THANKS
