First off, I am very glad I stumbled across this board in cyberland
The amount of technical knowledge I have read in some of the posts is astounding...
Anyway, I have decided to build a preamp
I am undecided on the Bride of Zen or the Balanced Zen Line Stage. Balanced inputs / outputs are not necessary since I do not own any equipment that uses them. That being the case, it would seem the Bride of Zen would suffice. However, if the Zen Line Stage made with the balanced inputs / outputs is a large improvement over the Bride of Zen, then I am tempted to go that route.
Any suggestions on which route to go would be greatly appreciated. Also, any help with choices on parts or help too. This will be my first true DIY from scratch anything, so I'm a little nervous
Thanks in advance.
Thanks in advance.
