Hi I've been working on a Bremen SQR46 with distorted audio on bass and mid range , so far I've replaced all the electrolytic caps on the board and cleaned up the pots. Top end is sweet now bass and mids signal is degraded.
I swapped out one of the output ic's but still no change.
Also when switching balance from left to right you can still hear low volume audio when there should be none?
Distortion is present on radio and cassette.
Any help with this appreciated, thanks
