can someone please tell me why it is my blackmax HT-5RH amp will not give output??,, I only get a very slight hum on the output when I connect a speaker... the hum is not DC voltage
I assume you mean Blackstar, not Blackmax!?
If so, it appears this model have some problems with overheating solder:
HT-5RH Problem - Official Blackstaramps Forum
It would probably be a good idea to have a look at R38 + R39.
I haven't been able to find schematic for the HT-5RH, but the HT-5H is out there, and should be fairly similar.
