Bitsa Amp project
Please bare with an electronics numpty! I have been bitten by the valve electronics bug and am probably being over ambitious. So far I have built a Chinese SE EL34 kit that I got working with not a little help here. Along the way I discovered how tolerant valve electronics are to some quite stupid mistakes.
So I was going to learn more by messing about with amp 1 however it is so much better than I expected I want to leave it working as it is now plumbed into my Hi Fi. Plan B is to build another amp from bits I have found and have as left overs. The idea is as simple an amp as possible again using EL34 as the power valve in single ended operation. I have a power transformer with two 6.3V 1.5A windings and a 250V 340ma winding without a centre tap. I also have a couple of output transformers that were recovered from an old Blaupunkt radiogram. These are fairly small physically so I am not wanting to put too much through them. I also have a couple of EZ81 rectifiers. So I have cobbled up a schematic based on a couple of different ones I have found and would appreciate an intelligent and knowledgeable eye to be cast over the result for suggestions as to whether it is likely to work or whether I have done something really dumb!
I think I have created a triode strapped output with no feedback. Driver is half of a 6N1P, I also have Russian 6H9C that could work in this position, not sure which would be better. I am aiming for about 4W or 5W as that is what I am guessing the output transformers are good for. Any comments, criticisms or help much appreciated with this project.
  • Bitsa Valve Amp.pdf
Ian,
Sadly I was given the Blaupunkt transformers already out of the original machine so I don't know what they were originally driven with. The Chinese EL34 amp is driving in pentode mode at 340V B+ which does look high according to the data, but seems to work OK. The screen is held at 225V by a 10K 2W resistor from B+.
