Looking for a solution for volume control.
Here is the biino Mk2 ver.
I found the time to assemble this in the end!
I don't use the input sellector board, only the volume control.
I have chouse the constant input version.
Not sure if it is the right option.
No problem with pops on mine. There was a problem with the bom showing 3.16k ohm instead of 31.6k ohm (Now fixed). I am very happy with the silent background low noise from this design.
Where is the problem, in the constant input or in the constant out version?
- Analog Line Level
- Biino Mk2
