BIGINNER'S CFA 120w amplifier
Disabled Account
Joined 2015
BIGINNER'S CFA 150w amplifier
793188d1573219024-biginners-cfa-120w-amplifier-output-jpg
793189d1573218282-biginners-cfa-120w-amplifier-biginners-cfa120w-jpg
793187d1573218282-biginners-cfa-120w-amplifier-mirror-jpg
793186d1573218282-biginners-cfa-120w-amplifier-cfa-input2-jpg
This my ever first CFA amplifier. To start with I chose the most basic topology but simplifying further the output voltage follower with a pair of complimentary lateral MOSFETS. This circuit has just born and needs some work . I looked around for a similar circuit to learn from , I submit it to your advice .
793185d1573218282-biginners-cfa-120w-amplifier-topologycfa-jpg
Why make things complicated when simpler functions better hæ. By eliminating the cascodes and replacing the mirrors with driver transistors I get even better distortion numbers. The open loop frequency now is 66khz!.
attachment.php
150w bootstrapped
By bootstrapping I could higher the output to 150w 0.5% , but the PSRR became 45db . So I modified the low level filtering .
If someone can explain me what I get better of using Diamond input stage.
attachment.php
