Hello all of you.
I am planning on doing a build in a couple months (after i save the money) to build 2-way floorstanding speakers.
The driver I am looking at, for my midbass, the MOREL MW-114S 4" DPC WOOFER. Has anybody heard these drivers? I think it's georgious and wanted ot use it in a design similar to I was thinking of doing a
T
M
M
configuration paired with the morel MDT-33 tweeter
OR
T
M
M
M
with a morel MDT-37
Impedance is not an issue as long as it's between 4 and 12ohms. I was thinking of going active crossover but I would need to have somebody design it for me.
I was also considering the cheaper MOREL MW-113 for a midbass. I guess this post is to ask for any suggestions. and if anyone has heard these drivers. Also, I'd like to add an integrated subwoofer and amplifier, similar to Definitive Technology floowstanding speakers if my budget allows.
Any opinions/information/suggestions please let me know!
DRIVER SPECS!!
Power handling: 150 watts RMS/210 watts max * Voice coil diameter: 2-1/8" * Voice coil inductance: .47 mH * Impedance: 8 ohms * DC resistance: 5.6 ohms * Frequency response: 55-7,000 Hz * Fs: 65 Hz * SPL: 87 dB 1W/1m * Vas: .113 cu. ft. * Qms: 2.32 * Qes: .36 * Qts: .31 * Xmax: 3.0mm
MOREL MW-113 4" MID-BASS WOOFER
Power handling: 150 watts RMS/210 watts max * Voice coil diameter: 2-1/8" * Voice coil inductance: .25 mH * Impedance: 8 ohms * DC resistance: 6.2 ohms * Frequency response: 70-6,000 Hz * Fs: 72 Hz * SPL: 87 dB 1W/1m * Vas: .15 cu. ft. * Qms: 3.13 * Qes: 1.03 * Qts: .75 * Xmax: 3.0mm *
MOREL MDT-33 1-1/8" SOFT DOME TWEETER
*Power handling: 200 watts RMS/280 watts max *Impedance: 8 ohms *Re: 5.2 ohms *Frequency response: 1,800-20,000 Hz *Fs: 700 Hz *SPL: 92.5 dB 1W/1m
MOREL MDT-37 1-1/8" SOFT DOME TWEETER
Power handling: 200 wattsRMS/280 watts max * Voice coil diameter: 1-1/8" * Impedance: 8 ohms * DC resistance: 5.2 ohms * Frequency response: 1,800-22,000 Hz * Fs: 700 Hz * SPL: 93 dB 1W/1m
T
M
M
OR
T
M
M
M
with a morel MDT-37
DRIVER SPECS!!
