BG13p Visaton design box
Hi all!
What kind of sound are you suggesting that I create (design) a box with the loudspeaker Visaton BG13p-8?
Please give some suggestion or a solution.
Thank you for your cooperation!
Did you ever make the BG200 Weems pipe box that Scottmoose designed for you or have you changed your mind and want to go with this driver? What are your reasons for choosing this particular driver?
Hi Mr xrk971!
Thanks for the question.;)
I'm not a failure ot the project has some problems with the procurement driver BG20.
These have in stock. I want create amplifier with the LM1875 and tube preamplifier or buffer with the 6922 or 6DJ8 (ECC88).:note:
Best Regards!
