I am running a pro audio set up in the back of my truck for outdoor event (car shows) pro audio use.
I will be running 8 beyma 12p80nd v2's and 4 beyma tpl-200h.
I understand from reading on forums that removing the felt pad and instead loading the horn into a larger damped rear chamber can further reduce distortion dramatically.
I was wondering if this would be beneficial for me in my particular application.
Thanks in advance fellas.
For the TPL-150H:
As far as I can remember, removal of the felt reduces second harmonic distortion which isn't very audible. Removal of the felt also decreases damping of the resonance at 1.6kHz significantly, causing a response peak. This may be more audible than the reduction in second harmonic distortion - the manufacturer obviously obviously added the felt for a reason.
I think the same applies to the TPL-200, except that the resonance at 1.6kHz seems to be better damped to begin with.
I would not want an underdamped diaphragm for a high power application. Perhaps better to measure and see what you get.
This is exactly what I did with my TPL150's and IMHO it does make a significant difference. It also creates a peak at approx 8Khz that needs EQ to tame though.
Great drivers though, I don't think they have a 'sound' as such, they don't 'shimmer' or 'sparkle' they just sound 'right' to me..
Regular
Dipole without help
Dipole without help
Sensitivity drop over 10db from removing felt?
Even the regular one is way different than measurement i did.
Are these acoustic anechoic chamber measurements?
One is normalized and other not, but is for reference (I only have the photos, lost the measures
I did the measures in my garden (Free field)
Cheers
sorry to ruin 1/10 tpl threads on diy audio.
find any similarities on my room measurement compared to factory sheet?
- Beyma TPL-200 felt pad removal?
