I want to deliberately kill a JFET, preferably without using the gate and hoping to obtain a short between gate and one of the other electrodes.
Reason: electret microphones always have a built-in FET, which can be used in common source or (after some surgery in the case of Panasonic capsules) common drain mode. One mike electrode is always connected to the gate and there is no way to connect to this electrode directly. In the case of the Sennheiser capsules, there is also a protection diode from source to gate.
I suspect much better distortion performance can be obtained from the capsule if a FET Op-amp was used as a follower. Or one could think about current mode, i.e. using a current to voltage configuration.
Anyway, the prerequisite is getting a direct connection to the second electrode (the first is the case). I guess trying to lift the small pcb will kill the internal connectors, so the most elegant way would be to make the FET fail with a short.
Anybody know if they fail as open circuits or shorts between the channel and the gate if too high a voltage is applied across source and drain?
I suspect applying a voltage pulse to the gate through the membranes (which do form a cap) is not a good idea?
Eric
Eric
