Best Temporary Solution?
Good evening all!
My Oris 250 horns and Celestion AXI2050’s are in and I’ve set them up with an active crossover at 388hz.
However, my bass enclosures and drivers are still at least 1-3 months out.
That said- I have two Acoustic Elegance TD18H+ 4ohm drivers I purchased off a member here-
What would be the quickest down and dirty way to utilize them only temporarily for the woofer / bass portion of this setup?
Open Baffle? Quick Sealed Enclosure ?
Thoughts?
I am too impatient to let these sit for 3 months with no midbass!
Thanks in advance.
There is just about enough timber to build 2 cabinets, each short of 100 litres, not counting driver volume, etc.
Vented is well suited. One sheet cut in half covers front and rear side. Second sheet suffices for top/bottom and sides.
edit: a vent 5(diam.) by 4" gives Fb=45 Hz. F3/F6/F10=52/44/38Hz
