https://www.madisound.com/store/manuals/SW26DAC76-4.pdf scroll down
ok I made a mistake, it works now- the 8 ohm in a 15 litre BR measures around 34 hz (F3) and F6 of 28 hz. Pretty impressive.
edit
madisound have got different specs to the SB website. sensitvity is 82 not 86!!
I don't understand how you can arrive at a 15L vented box for that driver.
For 15L sealed box Q is around 1, you cannot effectively vent Qb=1.
Qts of 0.52 means sealed for a compact box, with Vas of 44L, that
indicates around 30L(1cuft) sealed (and well stuffed) will get you
near the classic Butterworth Qb=0.7 alignment, just above in Q.
I'm fairly certain its intented use is 1cuft well stuffed sealed.
For vented around 60L (2cuft) tuned very low (18/20Hz) is what i get.
edit : sorry I've used the wrong driver data ........
Ok ... Fs 20Hz, Qts 0.27, Vas 46L .....
Yes that does make sense in a 15L box.
But note with such a small box the vent size will be so difficult
to dimension your will be forced to go with one or two PR's.
rgds, sreten.
