This has probably been answered before, but I couldn't find an answer by searching. I am rebuilding speakers I built in 1979 as the woofers needed to be refoamed and I replaced the caps on the xover. It is a sealed 3 way design and in remounting the woofers, I am wondering what has transpired since I built them in sealing the woofers to the cabinet. I used "wet" silicon caulking when first attaching, but the woofers were hard to remove as they stuck to the MDF and pulled some of the wood away from the cabinets when removed. I thought this would be the best seal especially where the bolts passed through. Is there a better way to get a good seal currently?
Thank you.
Thank you.
